If you have some heavy jumper cables you can troubleshoot the problem. have someone hold the starter button down and then you go directly from the battery post to the starter post, having all contact points clean. If it speeds up significantly then you know where the problem is. Do the same on the ground side, go directly from the battery post to a clean shiny spot on the starter. Do this one side at a time, although if your cables are too small jumpering both sides may be necessary.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
