Here"s some advice I was given and it worked great!
On break-in: Run it at variable throttle up to 3/4 under no load for 15 minutes to assure full coolant flow and operation of systems. Then use it for light variable loads for 10 to 15 hours. Change the oil and then just use it as you would but limit full continuous loads to 10 minutes or so for another 10 hours. Then make it pay for itself.
I followed this and the tractor runs great! Also, once the 15 minute warm up period is over have a buddy help you torque the head (110 lbs i believe) and do a valve job. If there is a leak or problem, stop the tractor and at least torque the head bolts warm to get that out of the way then address the other issues. ~Anthony
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
