Hi, quick fix is to bleed the right brake. Procedure is in owners manual also in archives for 454,574,674,684,484 and many other models have same brakes. The procedure can also be found in the archives. Check for leaking right brake cylinder under battery box and brake line leak that runs from brake cyl under cover over top of trans to under seat where it goes into top of diff by right rear axle. Probable cause as the other poster said leaking wheel cylinder O-rings.
Reason there are no brakes when both are pressed is there is an equalizer circuit between left and right brake all pressure will go to bad brake.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
