Posted by IHSMOKE on October 21, 2013 at 20:38:46 from (98.74.180.120):
In Reply to: 1420 combine engine posted by deereboy4010 on October 21, 2013 at 18:40:27:
OMG i just went through this last fall when someone else took off the injector pump and got the moter out of time...the pump can be removed without disturbing the timing gear ...it will wobble around inside the front cover but will not come out of mesh with the other gears ...take the rectangle cover off the front timing cover and DO NOT remove the 3 bolts from the hub this determines timing of the pump to the moter ... loosen the center nut and after removing the lines and linkage from the pump and mounting nuts tap the center nut with a hammer and allow the pump to fall loose it is keywayed to the hub that is bolted to the gear that i told you DO NOT REMOVE ..the 3 outside bolts ...simple
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
