yup, everything Cowman said, plus a little more. If the carb, timing, mag, plug wires, and plugs are right, these old girls will cold start in 1-2 cranks if your technique is correct.
Here is what an old timer taught me:
with the mag grounded, 1/3-1/2 throttle, full choke. Turn engine over 2-3 times. Set choke off, set mag to 1/3 advance, leave throttle alone. Start at the 6 o'clock position, and give a quick up pull, cupping your hand, making sure not to wrap your thumb around the crank handle. Most of mine (except the cantankerous F-12) start on 1-2 pulls. Everytime. When warm, no need for choke or to turn engine over with the mag grounded.
An F-series tractor, when right, starts EASY..........but everything has to be right. BTW, the above instructions assumes that the fuel has been turned on for long enough to fill the carb bowl.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
