farmallstrong said: (quoted from post at 23:20:51 10/28/13) I think the 504 bellhousing is different. You need a power unit from a combine. The crank needs drilled for the pilot bearing,and I think you have to cut some off the input shaft. Also you will need to deal with the radiator hook up.
farmallstrong is correct on all this
you can put a pilot bearing in your flywheel thats why you cut off the input shaft. that way you dont have to take out your crankshaft.
This post was edited by steve il at 17:38:57 10/28/13.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
