What screen are you cleaning. The filter bypass screen or the lube pump pickup screen. The one that will give you trouble is the screen on the lube pump inside the transmission. If your oil is getting hot it is because you are running under high pressure and has nothing to do with air. The system is self bleeding except for the brakes as they are a dead end. You need to put a gauge in to see what pressure you are running when all valves are in neutral. It should only be regulated pressure which is less than 300 psi at the pump discharge .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
