Posted by Janicholson on October 29, 2013 at 21:12:28 from (74.60.94.18):
In Reply to: 6 to 12 conv. posted by rcarraway on October 29, 2013 at 20:30:33:
A Hitachi 14231 alternator fits well, and is more tidy than a Delco. The wiring is the same as the delco (I would not use a one wire system) The #5 diagram in the link shows the diagram for a Faemall M. It needs to have a couple of modifications and an explanation. The Delco Shown has two small terminals. marked 1 and 2. The #1 terminal is L on the Hitachi. The #2 is equal to the S terminal. Use insulated 1/4" female spade terminals to avoid the connectors touching in the alternator. You will need to reverse the leads on the amp meter. You will reverse the leads on the coil to match the diagram. You will need to add a ballast resistor (Chevy 64 V8 will do fine) as shown in the diagram ubless you use a 12 volt coil with no resistor needed. The diode can be a little thin in the wires. Putting it into the system and soldering the leads so that it forms a Z makes the leads double back on the diode and when taped up makes it stiff and less prone to breaking. (make sure the Band end of the diode (elecrtically) faces the alternator. All bulbs need to be replaced with 12volt. Using LED headlights makes real light to drive by! and last hundreds of times longer than regular bulbs. Search the net for the correct base and shape. All other connections remain the same. The starter and relay will work fine and spin correctly with reversed battery connections (negative ground) Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
