Steve706, It's a relatively simple system, so it won't be too hard for you to figure out. Seeing as you say you have NO power to anything, it rules out all the minor stuff. If you have a meter it will be a bit more informative, but even a 12V bulb on pigtails will give you solid clues.
First, check the battery at the terminals - a bulb should glow brightly, or a meter show at least 12.6V (half that if it's a 6V system). Next, move just the grounded test lead to some point on the chassis - it should show the same as on the battery itself. If it doesn't, you have a bad ground connection between the battery and chassis. If it shows good, then move the "high" side test wire to the battery stud of the starter. If it doesn't show good, you've a bad connection on that side of the battery. Not that this next step applies to the 100, but with any tractor that starts from the key switch (rather than a starter rod), if you have power at the starter stud and chassis but nothing beyond (like lights) the probable fault is in the "fuseable link" - the smaller, usually 10 AWG wire that goes from the starter stud to the ammeter and the rest of the electrical stuff on the tractor. Some of them are actually fused! Most from the 40's to 60's aren't.
Yes, battery connections can give out 'just like that', and usually, it's the positive terminal that needs the cleanup, be that the grounded or high side of the system. If the battery clamps have been replaced, there is a chance that the wire clamps have a bad connection.
Hope that helps. If not, let me know and I can walk you through a more through set of tests.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
