"David Goode"] I peeked back in the archives and edited my reply to -->
LarryNMO
PostPosted: Tue May 28, 2013 6:56 pm Post subject: IH460 CARB ADJ
What is the adj. on the top needle setting and on the bottom adj. screw. Thanks Larry
Al L. in Wisc.
Long Time User
PostPosted: Wed May 29, 2013 5:03 am Post subject: Re: IH460 CARB ADJ Reply to specific post Reply with quote
per the Preventative Maintenance Manual: "The engine and carbutetor [yup, misspelled in the book] are correctly set when shipped from the factory.
Again, from the IH book dated 6-20-58 - with the engine thoroughly warm, turn off. Close the [top needle] idle adjusting screw to its seat; then open one turn. The [bottom adj. screw] main fuel adjusting screw can be used to reduce the amount of fuel going into the engine when under light load conditions. However, when heavy work is to be performed in which the FULL POWER of the engine IS REQUIRED, the fuel adjusting screw should be set five turns off its seat. With the engine running at fast idle, turn in the throttle stop screw a few turns to prevent the engine from stopping when the throttle is closed. Start engine, close the throttle by pushing the engine speed control lever all the way up. [I like the way they worded that.] The throttle stop screw can be backed out until the desired idle speed (approximately 425 r.p.m.) is obtained. If the engine misses or rolls, the idle adjusting screw may be adjusted either in or out until the engine operates smoothly.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
