Posted by Allan In NE on November 15, 2013 at 07:30:33 from (199.47.66.63):
Let me bring this issue over here.......'cause I think I'm drivin' 'em nuts over n the Red Power board. :>)
5488 no power steering assist. Engine does not "labor" whatsoever and no noises.....it's as though there is no connect between the hydraulic assist and the manual pump. Everything else hydraulically works as advertised. Just no help on the steering. :>(
I know I should put a pressure gauge on the goofy thing (don't have one). The PTO engages, and both the hydraulic warning lights go out as they should. So, I "think" I have pressure?
I jacked the front end off the ground. Doesn't seem to be any binding at the front end. Manual steering does not slip at all, although it is still a little tough to turn.
I've replaced both belly filters, been all through that flow divider and the PS relief valves.....everything seems to be in order there. Absolutely no contamination or metal pieces in the oil.
There is oil pressure to the cooler and the hydraulic seat works good.
What would be the symptoms of a bad manual pump? If the steering cylinder was leaking inside, I'd have some slippage of the steering wheel wouldn't I? How would a guy eleminate these two items from the 'problem list'?
I don't mind buying that expensive pump, but I want to make darned sure that is the culprit first.
Oh and one more thing; the brakes seem a little 'lazy' to me.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
