Re: dry sleeves
Posted by Tom Fleming on November 16, 2013 at 09:43:54 from (67.20.233.75):
In Reply to: dry sleeves posted by Steve43 on November 13, 2013 at 10:59:28:
sleeves when new, should be snug, but not "tight". Also, the metal ring around each bore is also part of the whole setup for the sleeves to stay in place. Personally, I would install them as is, and make sure you have the correct head gasket with the metal rings around the cylinder holes.
I know for a fact that some wet sleeves I have installed were not sloppy, but definately not tight. When I turned the engine over prior to installing the head, they moved a bit. Those engines are still running just fine, with no issues.
it's your tractor, and your decision. Personally, I would go with it. your mileage may vary.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
