Posted by John T on November 22, 2013 at 11:53:08 from (216.249.76.176):
In Reply to: Re: 200 Coil Update posted by wayne in mn on November 22, 2013 at 10:53:16:
Good point, an actual HV Coil tester is the way to really know and test under actual High Voltage conditions. A low voltage low energy continuity test can tell if a coil is definitely BAD (like an open winding) HOWEVER its common for an actual failue to be due to high voltage breakdown and a continuity or ohm meter test doesn't indicate that test.
IE an ohm meter test cant tell you if a coil is really good even if it passes primary and secondary resistance checks.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
