Posted by Stumpy(NH) on November 28, 2013 at 16:00:14 from (71.169.175.116):
In Reply to: Super H Missing posted by DV on November 27, 2013 at 17:27:14:
Just another angle on the problem. I have an Oliver Super 55 that did exactly the same thing. I found it to be number 4 exhaust valve sticking lightly.
Try finding which cylinder is missing at idle by removing and replacing the plug wires until you find the cylinder. Remove the valve cover. While the tractor is running place the blade of a large flat screw driver in the coil of the valve spring to add tension. If the engine stops skipping, you have found your culprit. It most likely will not be an intake valve or it would be backfiring through the carb.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
