Posted by Janicholson on November 29, 2013 at 15:11:00 from (74.60.94.18):
In Reply to: Super H wiring posted by burnt-smta on November 29, 2013 at 14:42:41:
You need either a diode in the wire going to #1 terminal, or a 10 ohm resistor, or a marker lamp (Bulb not Diode). This will feed the #1 terminal with ignition voltage from the switch side of the ballast resistor. and prevent discharge. The #2 terminal wire should go to either the battery+ at the starter switch, or the big terminal right there at the alternator (short wire). Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
