Super C hydraulic pump?
Posted by lti on November 30, 2013 at 20:32:35 from (67.55.255.159):
The pump that is mounted to the front of the engine by the distributor. What does that run when it came from factory. Have one here that has the outlets hooked into a valve then 2 outputs on back to run a 2 way cylinder. They also added a small tank in one of the hose runs to hold extra oil.This tank was in the way of a 2 row cultivator on it sevral years ago, took tank off and spliced hose together. Never used the dual outlet seems to be some preasure pulls engine without tank when valve lever is pulled.Hopefully we didnt do any damage to pump by taking storage tank out of the circut about 4 years ago. Main question is what did that run from factory.Thanks
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
