Re: start on farmall m
Posted by rvirgil_KS on December 02, 2013 at 14:48:12 from (192.208.173.110):
In Reply to: Re: start on farmall m posted by butch49 on December 02, 2013 at 13:20:38:
With negative ground, the negative post on coil should go to distributor, positive post to ignition switch via resistor if used.
With switch on, approximate voltages at the coil should be:
Input (switch side) without resistor 12 volts, with resistor 12 volts points open, 6 volts points closed.
Output (distributor side) 12 volts points open, zero volts points closed
Sounds like the coil wires may not have been switched when alternator conversion was done.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
