Posted by Owen Aaland on December 03, 2013 at 14:39:01 from (216.47.35.11):
In Reply to: start on farmall m posted by mkirsch on December 03, 2013 at 05:42:35:
There is no voltage drop in any circuit unless it is a complete circuit from positive to negative. The points make up the switch to open and close the circuit. With the points open there should be no voltage drop anyplace in the circuit. If there is a voltage drop across the coil with the points open then you have another path to ground other than the points. That may be a short in the coil, bad condenser, or short in the wiring between the coil and points.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
