Very unlikely to find any crossover, Do as Gene indicates. .032-.040 or so thickness. If it is taken apart, use the cap and a pen to mark the holes and outline, then cut with scissors and razor knife. If the wheel is mounted cut the hole for the axle, slit the top at the center, and slip it over with the cut as Gene indicates. Put the bolts into the holes and push to mark them, mark the outside edges, remove, cut, Put on sealer, and put it together. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
