Posted by Dan MD on December 08, 2013 at 15:34:44 from (184.158.35.101):
In Reply to: 450 injectors posted by 450dieselfan on December 07, 2013 at 16:40:05:
Wish I could help you. Maybe try a compression test through the spark plug holes with the starting valves both open and closed. Would give you an idea of the condition of each cylinder and also to make sure your starting valves are closing 100%. On my SMD, I get a compression reading in the mid 120's on all 4 cylinders and then zero with the valves closed. Also, when you open the bleeders, are you opening them the same amount, and what RPM range are your doing it at?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
