Posted by riverbend on December 09, 2013 at 10:49:59 from (184.12.40.153):
In Reply to: '42 H Carb Help posted by Farmer Matt on December 09, 2013 at 10:25:03:
I din't think gas should pour out, but some gas will drip from the bottom of the carb if the choke is used for a extended period.
To start my H (distilate carb) I pull the choke out all the way, crank it two or three times (ruh-ruh-ruh), open the choke, open the throttle 7 or 8 clicks, turn the ignition on and crank it again. Usually it fires and then I use a little choke to smooth it out until it warms up a little.
These tractors are all different so you will have to figure out what yours wants to start. Having a good set of points and the timing set right are critical.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
