Posted by Ron W on December 10, 2013 at 08:47:59 from (216.11.184.78):
In Reply to: Plow for f-12 posted by Dave S. on December 09, 2013 at 16:24:29:
I have several f-12/14 and plows, and have done many a plowing with them.
My grandfather bought a f-12 with a single 18" bottom lil' genius back in 1935. He farmed 80 acres with it along with a team of Morgan horses. We have sandy loam, swamp land, but very little clay. I rebuilt the tractor when I was 12, and I am still plowing with it in third gear on the sandy loam, second in the swamp land, and first in heavy clay. I like to use this plow for deep turning or sod busting because I can drop it deep in the ground.
I have pulled a double 12 with this tractor in sandy loam in second with ease. There are no special pistons in the tractor, nor modified carb, just the same OEM style parts. I do put in about a quart of kero-or-diesel-or-fuel oil for every 5 gallons of gasoline to make up for the lead removed in the gas and keep the rings from sticking when they sit.
I do have a triple 12 plow, and tried it once behind a f-12. Best I could do was first with wide open throttle in that sandy loam.
Now you can have a good tractor, but if you don't set the draft lines right, you'll loose traction, waste horsepower and it won't pull s!@#. If you can get a hold of a McCormick Deering plowing handbook, it is very valuable in setting your plow up right.
Keep in mind that comparing an H or M to a F12 is like comparing a f350 to a f150 in towing a goose- neck. The F-12/14 is a great little tractor; it was designed to be smaller than a regular/f20, and is comparable to having a team strong Morgans or light Percherons (Draft Horses). I know this from personal experience working with both. The tractor was also priced lower for the small farmer (20-75 acres)to afford. I have regulars and an f30 and if I need the horsepower, I am happy to use them. The f-12's though are very economical on gas; even with plowing.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
