IF the hyd's were working one min and then not the next and you found nothing in the hyd. filter . And you have no hyd. at all hitch remotes steering brakes , the you have more problems then you want . It may vary well be that the drive center on the pressure plate either stripped the splines or the rivets let go . And if this is infact the case you will have to split the tractor and replace the clutch pressure plate , pilot bearing IDPTO input shaft new seals and a new bearing . Also when your remove the hyd filter you always replace the gskt. never ever use the old gskt or use guppy GOOO .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
