Posted by mountain4don on January 01, 2014 at 13:46:27 from (71.1.123.92):
My original gas valve/filter on my 1954 gas fired Super C Farmall was pretty corroded and the filter screen rusted out of it, so I decided to replace it with one I bought from Orscheln. The new one went in ok, but when I turned the valve on with gas in the tank it leaks around the glass bowl. The rubber gasket inside just seems to want to slide into the center inside of the glass bowl and leak. And I don't see how this rubber seal trapped between the glass bowl and the filter screen pushed against the metal body is supposed to seal anyway. I would think that the gas will just leak horizontally through the screen to the outside. What is the solution to this problem? Or are these gas valve/filters just no good?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
