As to your noise up Ft. i have no idea as i did not hear it , But if something is heading south you will be the first to know it . Now as to your lack of MCV pressure lets start off by changing the hyd filter amd taking a good look at the oil that comes out when you pull the cap off the filter. If it is the least bit cloudy then Change the oil because it has moisture in it and that misture is causing the filter to plug and you are starving the MCV pump if your tractor has the open center system if your tractor is the later 86 series and has the PFC system with this i am not that good on that system and either Pete or Owen know more then i do. When you go to buy filters never just buy one always keep a stock of hyd. filters on hand and the o/rings and or the gskt. always change then with each filter change. The MCV pump is always the last to suck up oil and when the filter starts to plug this is where you start to see the problem . Cold weather will bring out problems with hyd.systems and fuel systems .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
