Hardest job is to loosen the driveshaft bolts. They are tapered and hard to loosen. This is how I have "easily" loosened them: 1. Turn shaft(clutch depressed or rotate engine) so bolt is on the bottom, 2. Take a combination wrench and place box end on the bolt head, 3. Remove nut & lock washer with second wrench or socket, 4. Take a larger combination wrench and lock the box end into the open jaw of the first wrench so you have (in effect) a longer wrench. ( this will test the lifetime warranty of the tool!), 5. Place transmission in 1st or reverse (clutch pedal released so engine resists turning) and lock the brakes. 6. Apply firm pressure to turn the tapered bolt; when it "snaps" the bolt can be removed. You may need a pipe wrench to help hold the shaft &/or coupler from turning. Remove the two bolts on the shaft first and the coupler bolts last. Heat or hammers, etc. may do the job but simply turning the bolt works so much easier & faster.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
