Posted by John T on January 10, 2014 at 09:20:40 from (71.0.66.0):
In Reply to: 12v coil posted by sparky70 on January 10, 2014 at 07:38:46:
One converted to 12 volts, the choices are:
1) Keep the old 6 volt coil and use an external series voltage dropping (12 to 6) ballast resistor.
2) Use a full true 12 volt coil (some call internally ballasted, although there's actually NOT any discrete stand alone resistor hidden away inside lol)
One advantage of a 6 volt coil plus an external ballast, however, is the ability to use a start ballast by pass circuit, so when cranking the coil sees un ballasted battery voltage for potential improved starting especially if its cold.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
