you maybe able to fix that dead spot on the throtal under the hood on the head where leakage has springs on it with 2 nuts , them springs may also be so weak they dont work , have had that problem myself in the past , the new spring is stronger even if its longer, so them upper springs need to bottom out befor throtal will respond , also how worn is the shaft on the govener arm coming out of the back side. if its worn like most, factory settings wont cut it need to compensate for that slop ,ive restored lots of H"s & M"s and every one seems to have a differant fix to the problem , youll have to play around to get it right, have one now that works fine but doesnt respond like it should has me scratching my head tryed lots of different settings and still dont work the way youd like it to respond in the field , my H has a home made throtal shaft from head to steering post with new upper springs and lock collars so it can be adjusted anywhere on shaft , that one works great as soon as the engine even thinks it needs more it responds & with a saw tooth handle it changes RPM on every tooth like it should , it takes some time & some playing around but youll get it , check them upper springs thow
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
