As has already been said, begin with the basics. Make sure that the points, condenser, plugs, plug wires, coil, battery, and all associated wiring is in good order. Set the timing correctly. Then, make sure the carb. is operating correctly, clean and not plugged, fuel not stale, and there is adequate fuel. If the engine is in good condition, and all of the above items are correct, it should start and run well.
One must remember: these are very simple engines, ignition, and fuel systems, and were design for easy starting. You can say that it was an imperative. These old tractors were designed to be as easy and trouble free to operate as possible, hence their simple construction.
To illustrate the previous, I own the first truck I ever drove, a 1949 Ford F-2. This truck is all original, complete with a flathead V-8. Although the body is rough, mechanically I have alway been meticulous in maintaining it. The engine was last gone through some 23 years ago. In 2012 I decided to resurrect the truck after it had sat for 13 years. Knowing I did not want any hassles with starting or reliability, I very carefully went through the fuel, wiring, and ignition systems. The result is a truck that I drive back and forth to work everyday (which isn't far, 3.1 miles, don't want to wear it out). This past week, we experienced lows in the evening of around -16. On the coldest day, I had to employ a heat gun directed at the battery to get it to start, but it ran flawlessly. It also still sports a 6 volt system.
The point is, make sure that the ignition first, then the fuel system are at factory spec. and condition, and the old girl will run and start fine.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
