With a very tight press fit. Very tight. You need a bearing splitter, and a piece of 3/8 plate steel, and a ten to twenty ton hydraulic jack. Check the picture in the link. To see more pictures click on "Project Journals" in the left hand margin of the page, then click on "Farmall C Trike, SouNdguy.
To put the pulley back on, you use a piece of 1/2" all-thread, a good 1/2" nut, a small plate of steel with a hole, and an 2" pipe coupling. At least that's what I use.
I have seen some pulleys with a bolt in the center of the crank, and I have seen some with set screws, but most are press fit. Good luck with it.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
