I don't think there is much that can be done within the steering box. Had mine apart a couple of years ago and the internal parts were fairly tight. The box itself had a considerable amount of wear at the top hole for the steering column and some wear in the hole for the pitman (output) shaft. If I remember correctly, there are no bushings used on the shafts. A lot of slop in the steering system was found at the worn holes in the rectangular block that connects the pitman arm to the drag link. I have also seen several of them where the pitman arm is loose on the spline on the output shaft of the steering box. Did you check all of these items to ensure that the play is not form other points in the steering system?
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
