Posted by Loren in MN on January 30, 2014 at 15:31:41 from (75.168.61.103):
A few months back, I mounted a second hyd valve under the seat of my 756 gaser, but didn't have the correct piping for the left hand(second) valve. Did have a second somewhat bent set of piping for the right valve when mounted as two valves and piping for a single valve, so I modified one set of tubing using the original single right piping from the front outlet, then changing the right rear tubing, then using the damaged right valve tubing for a two valve setup, modified it to fit the left valve and rear left outlet block. (If all that makes sense?) Someone asked to see pictures of the tubing. All works well, my son did the tig welding. Attached is also a pict of the correct piping in another tractor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
