Posted by Haas on January 31, 2014 at 14:34:19 from (50.142.111.41):
In Reply to: Farmall A fan hub posted by Farmall A Tractor on January 31, 2014 at 12:46:36:
Use the same oil you use in the engine. D7 has it right as to how to fill the hub. There is a stand pipe inside the hub that drains the oil to correct level when you turn the fill/drain hole to the bottom. I would not use grease. This hub is designed so that rotation causes the oil to circulate through the bearing. You won't get that if you use grease. Pretty good design as many still going after 70 years!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
