Take the wire off of the distributor at the distributor. With plastic handled pliers, brush it against a ground (shiny metal) with the ignition turned on. If it sparks a little when touched to ground, there is voltage where it should be. Shut off the ignition. Next open the cap and put a small piece of plastic (strip of butter tub lid or the like) between the points. Now, while the cap is off, and the ignition on, touch that loose wire to the distributor terminal where it belongs. If it sparks a little there, the points are grounded to the distributor housing and it could be the condenser wire, or the through stud, or insulator that are causing the problem. There should be no spark. Next remove the plastic, and make sure the points are together. Now touch the wire to the terminal if no spark, the points are not conducting, and need to be cleaned and polished. A good polish is a paper match striker stripe. Then wipe them with a folded dollar bill. (no lint) The point gap is .020" when the cam is pushing the points open as far as possible (High point of the 4 lobes) If there is wobble in the distributor cam, it will never run correctly. The movement must be less than .001" at the cam. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
