You indicate you have the high low charge switch on your H. What that switch does is ground the field of the generator. On low charge it goes through that resistor on the back of light switch. Oh high charge and with lights on the switch grounds the fields directly to ground . So, the switch has to make good contact to the cover, cover has to make good contact to the box in order to complete the connections. Most likely when you replaced the fuse you no longer have a good connection from cover to box. Stick your pocket knife blade between cover and box to see if that makes it charge. If so, you have found your problem. Then clean up the cover and box for contact. I often times run a ground wire from the light switch to a good ground to eliminate all those crappy connections.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
