I'm sure the key way and the bearings can be gotten from Motion Industries pretty easily with a little part number research (or use numbers from old ones). The bushings can be made at a machine shop if you'll remove the upper and lower castings. The gaskets should be really easy to get.
If you wanted to convert it over, get a good used shaft on eBay or parts place, then the new rebuild kits are EASY to get (for about $65.00) and come with bushings, seals, bearings, and gaskets.
DO NOT use parts from an old unit if you are rebuilding....swapping the whole front end is a different story. Will be like new in the end.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
