Patrick, I use Bar's leak with great success. However, I use the liquid with the pellets. However, you need to follow the directions carefully. It is rather simple, but before you put it into the rad, the tractor MUST be up to operating temperature and the coolant ciruclating. Then, after you put it in, work it a bit, at least for 30-40 mins. It is compatible with antifreeze, so no need to drain the cooling system. It is also good for water pumps, as it has a lubricant in it.
Others on the site are not so big on this, but, I need to be clear. if you don't have the tractor up to operating temp, you will have issues. If you follow the instructions on the bottle, you will be pleased with the results. Other's may disagree, but I like it and I use it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
