Pull the bolts off the side cover of the gov. and take a look . (1) see if the spring that hooks to the two arms is flopping around in big holes. (2) If this is the case then the bushing in those arms are long gone . There is suppose to be tow harden bushing in those cast arms and the holes are beveled on each side and the hole is a little larger then the dia. of the spring wire . The spring does two things it regulates just how high the RPM is suppose to get at a give tension and ALSO push it back to idle . Then also the thrust bearing could be shot . Then you also have to synchronize the gov to the gov. linkage to the carb . Then ya need to go thru all the throttle linkage and repair rebuild and fix .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
