Posted by eastsider on February 16, 2014 at 13:25:28 from (24.111.75.41):
Since I see a lot of questions over the years about how to remove the old, rotten exhaust pipe from the manifolds, I thought I would share the procedure I always use. I am restoring my H right now, and had to refurbish the manifold recently.
Step one...carefully use a Sawzall to cut through the old pipe...this can be done either on or off the tractor. This one happened to be off.
Step two: Make a couple of careful cuts into the threaded area with the sawzall again, being careful not to cut into the manifold if possible. Once done, chisel out the small chunk and the rest will peel right out.
Step 3: Wire wheel, bead blast and scrape, scrub etc... Make sure to clean out the drain holes on the bottom. They are more than likely plugged up! See the difference? Then clean out the threads...use a pipe tap if you have one, or a dremel tool works well too.
Clean it inside and out, I use brake cleaner! Blow it clean so all the glass beads are gone, and reinstall. I don't know what the markings here mean...did I really find an M&W replacement manifold, or are these casting letters from IH?? There was an IH part number on it too. Any thoughts??
I hope you can use this for your restoration someday!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
