Posted by JimB2 on February 17, 2014 at 13:47:32 from (99.240.243.222):
In Reply to: Hydro 84 posted by Dieseltech on February 17, 2014 at 06:57:34:
Hi Dieseltech,
Yes, looking at parts book the Hydro 84 appears to have same PTO setup as 684/784. My brother had a 1000 RPM PTO installed in his 495. It took CasIH mechanic about 1 hour to do the job.
From archives: Installing 1000 RPM PTO: Hi TWafer and JB2, you have to buy the 1000 rpm PTO shaft, the cover with a hole and a seal. Remove the shaft, by removing the spring pin that holds it in the PTO clutch pack, and the rear cover. Place the 1000 rpm PTO shaft in place, secure with the spring pin and bolt the cover. That's it. Bernard le mécano Québec Canada
Hi TWafer, yes, you remove the pin by the right round cover. Hold the clutch pack when you pull on the shaft. Make sure to align carefully the shaft with the clutch pack before you press the spring pin. Bernard le mécano Québec Canada
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
