Posted by WellWorn on February 23, 2014 at 18:17:23 from (75.213.114.54):
In Reply to: Super A Plow posted by Brutalfly on February 23, 2014 at 09:09:26:
I'm not sure what your mean by "and neither are the arms that go to the hydros".
Probably the most common plow for the SA was the #93, single bottom. I have one, and it works quite well. Bought it a few years ago for $75.
Unfortunately, besides not having a way to get a picture uploaded, the plow is currently buried in a couple feet of snow. I may not even see it for another month.
Yes, you will need both hydraulic rams working (IH's famous "Touch Control") the right lever lifts or lowers the front of the plow beam to adjust 'draft' (amount of downward 'pull' from the plow point), and the left lever raises and lowers the back of the plow beam for depth of furrow. Once you have it turning the furrow nicely, there are 'thumb screw stops' for the TC levers, so the settings are repeatable.
The front link for the plow is an adjustable rod that bolts to the U shaped draw bar turned to face the front of the tractor (comes to just forward of the rear tires). The front of the plow beam bolts there too. The back of the plow beam is suspended by a chain and special "J" link that hooks to the right rear lift arm.
I know it probably sounds Greek, but if you could see it set up, it would make perfect sense.
Probably someone else has pictures. If you would like them, just ask.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
