Posted by JimB2 on March 01, 2014 at 05:39:27 from (99.240.243.222):
In Reply to: 364 heating posted by ironhorsedriver on February 28, 2014 at 14:44:12:
Hi, yes, stuck thermostat can cause over heating. Depending on the age of your BD-154 there should be a thermostat bypass. First I would check that the new head gasket is not leaking into the coolant. When engine is cold, remove rad cap and start engine and let it run until it is warmed up and observe coolant through rad filler watching for air bubbles. Also coolant level should be just above the rad core when cold and 1/2 inch or so below the bottom of filler when warm. After engine warms up and thermostat opens you should be see the hot coolant circulating on the top of the rad. If you have access to an infrared heat gun, you can check engine block, top to bottom rad temps. Top should be hot, bottom cool. Other things to check are: 1)Bottom rad hose for collapsing 2)Clogged rad cores, all the hot coolant stays at the top 3)Air flow through rad 4)Stuck thermostat, can removed and replaced
Caseih.com parts: 3042303R92 is a replacement part for the obsolete part(s) 369322R91, 180F degree thermostat. I cannot recall if BD-154 uses a standard automotive thermostat or not.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
