Posted by Janicholson on March 02, 2014 at 10:01:24 from (74.60.94.18):
In Reply to: super A steering posted by arkansas red on March 02, 2014 at 08:59:50:
Not as in a screw and jamb nut. Looseness is found in three places caused by lubricant leaking out. The ball bearing at the far end of the worm under the cap, can be worn and allowing the shaft to either screw in and out (it should not move in and out of the box), or it allows the worm to be displaced sideways away from the sector gear making slop. Second is the bearings in the sector/steering shaft (vertical shaft with arm underneath). These wear (especially the top bushing) and allow dramatic slop as the top of the shaft moves when effort is applied. the third (common) is a bad Keyway in the arm to shaft. These frequently get wallowed out and allow 1/2 turn in the wheel of freeplay. New bearings and bushings are usually the solution for the first two, and re machining the shaft and arm for a bigger woodruf key is the solution for the last. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
