Posted by Jim Naden on March 15, 2014 at 02:11:52 from (70.198.64.177):
In Reply to: 1486 range stuck posted by idahofarmer on March 14, 2014 at 15:22:07:
The bar on the high low shaft can loosen and cause this problem.
The original design used a very small flat washer which would not keep the bar tight. That has been replaced by a heavier, hardened flat washer CIH p/n 87613287. 1" OD by .098" thick. ($1.90)
Avoid using too thick of a washer due to low clearance between the bolt and the speed transmission shift rod.
While you're working in this area, give all pivot points in the shifting mechanism a good lubrication.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
