Posted by The tractor vet on March 16, 2014 at 15:53:35 from (75.19.115.57):
In Reply to: 1086 gears grinding posted by Russell Moore on March 16, 2014 at 12:46:52:
Well first off lets start with getting ALL the clutch adjustments done First since there is more to it then just adjusting the CLUTCH . First ya adjust the free travel on the clutch , then ya adjust the transmission brake , then ya adjust the DUMP valve . If you have never done this before and have no idea on what your doing you need a BOOK and you can also search back back thru the archives as i have gone over this many times . Yes a 1086 is a little different then a )6-66 sires but not that much . Next off there is NOTHING in any I H transmission of those years that is a syncro . AND gears will grind , now IF your are good at double clutching and can chew bubble gum and walk across the street rubbing your tummy and patting your head all at the same time then you can shift a I H tractor with out grinding gears .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
