Re: 1466 Trans. problem
Posted by Jim Naden on March 18, 2014 at 01:14:10 from (70.198.69.156):
In Reply to: 1466 Trans. problem posted by Rodney Sequeira on March 17, 2014 at 16:28:04:
Rodney Sequeira said: (quoted from post at 16:28:04 03/17/14) I have a 1976 Farmall 1466 tractor that has begun to make a noise in the transmission area. When I pulled the dipstick (located above the transmission in the cab), I noticed it had a newly made mark as if something was rubbing against the dipstick.
Any idea as to what I may be looking at?
Thank you.
Is the noise most prominent in low range and reverse?
If so, the range counter shaft bearings are most likely failing.
If the noise is present in all ranges and increases pitch with ground speed then it's probably the pinion bearing.
This post was edited by Jim Naden at 01:16:25 03/18/14.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
