Posted by gbs on March 19, 2014 at 19:39:19 from (68.115.212.154):
In Reply to: 706 MCV issues posted by red48m on March 18, 2014 at 13:51:00:
not an expert on mcv's but I've run into the pressure bouncing,it can be caused by cavitation add about 5 gallons of fluid more than it holds full and see if that helps the pressure bouncing, check the dump valve to make sure it's seating,also remove the bottom plug in the mcv valve then remove the pressure relief valve that is above the plug the o-ring will go bad and lose pressure,it is non serviceable look it over to see if the spring is damaged or valve is stuck open,it would pay to pressure and flow check the mvc pump,don't want to tell you wrong but if I remember correct the pump should produce around 9 gpm at 1300# psi new, don't know what the minimum is ,roughly 4.5 to 5 gal is priority to the steering & brakes rest is for TA and lube
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
