vertical distributor
Posted by oregonfarmer on March 31, 2014 at 07:59:25 from (70.210.138.10):
It took a while to find the housing so I could put a distribuor verticaly mounted on my M. Some wondered why I would want to replace the magneto anyway. The M has a hydraulic pump running off the cam gear and then comes the vertical distributor housing. I was going to use a IHC dist (one that seems to fit all models), but the gear is wrong. THe drive gear is a worm and doesn't mesh with the dist gear. Is it possible that these verticals were intended for use with a Delco and not IHC?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
