The clutch pedal has a square headed stop bolt with a lock nut just below where the linkage from the front attaches to the pedal itself. Assuming the free travel has been set at 1 in from the deck plate, and the T/A lever linkage has been adjusted to give the correct free travel, per the manual, it sounds as if the new clutch has " worked itself in", I would back the stop bolt off a turn at a time until the tranny doesn't grind when going into gear. The clutch has "worn in" since you have really been working the tractor, that's all. If adjusting the stop bolt doesn't fix the grinding into gear, then the advice given above would be a good place to start.
The only other issue I can think of is on my 55 F300, the T/A "stops" the tranny when pushing the clutch pedal all the way down when stopped, about 1/2 to 3/4 in from the bottom the clutch is released from the engine and the T/A is just beginning to catch on the way out ? Hopefullly... someone more experienced here can explain it better, but I could never get the free travel, clutch pedal, T/A lever adjustment synchronized until I purchased a manual, once I adjusted everything in sequence to the manual & to the specs given, no more shifting problems.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
