Re: Re: Int. B275 Difflock
Posted by lee on December 22, 2000 at 13:39:06 from (198.133.22.93):
In Reply to: Re: Int. B275 Difflock posted by Andy Sinnamon on March 05, 2000 at 06:05:34:
You say it's like a locked box in your hands, but is it not still on the tractor?
All suggestions must be taken with a grain of salt with no guarantee suggested or implied.
I cannot recall exactly, but it seems there is a retaining ring in hiding on the shaft there. I think you have to pull the shaft out or depress the part the shaft passes thru (one or the other) against a rather stiff spring pressure to expose the retainer. I vaguely recall this as a challenging task to expose the clip and remove it against the spring pressure. You may want to enlist someone to help.
Assembly may be your next trick. I've not done that as yet. Looking ahead, I doubt you've removed your hydraulic housing. We can only hope you don't end up going there before it's all over. In all fairness, I don't think you should end up to your arm pits in hydraulic oil just to replace a shaft seal but I'd take a good look at a manual
to insure myself there's no chance that's where this leads. I can look at a manual and get back next Tuesday. Have a good Holiday.
Post A Followup
: Re: Re: Re: Int. B275 Difflock
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
